Issue with h7 led bulb
ChocoMilkShark
123
8
Hi all hope you can help.
I'm having issues with my led bulbs I just got, my passenger side fits perfectly but the drivers side does not it sticks out by about 1cm so the cover will not fit back on. Is there something I have done wrong?
Legojon
I only wanted a remap
5,316
2,748
Hmm. I remember the drivers side being more awkward to get back in. But I definitely got the cover back on. If the passenger side fits driver side should be identical. I'd check it again make sure it's seated correctly. When you look through the front of the headlight does it look the same position as the passenger?
ChocoMilkShark
123
8
I've checked and redone it 4-5 times and I even swapped the bulbs round just in case it was the reason but I think it's just the bulbs are too big so I ordered some more for tomorrow so il update then
saveoursouls
415
234
37
Manchester
Which bulbs did you go with? From what I understand you have to spend quite a bit to get LED bulbs that produce the correct beam pattern as to not blind others.
SWANSWAY CUPRA Dealership
