I'm having issues with my led bulbs I just got, my passenger side fits perfectly but the drivers side does not it sticks out by about 1cm so the cover will not fit back on. Is there something I have done wrong?
Hmm. I remember the drivers side being more awkward to get back in. But I definitely got the cover back on. If the passenger side fits driver side should be identical. I'd check it again make sure it's seated correctly. When you look through the front of the headlight does it look the same position as the passenger?
I've checked and redone it 4-5 times and I even swapped the bulbs round just in case it was the reason but I think it's just the bulbs are too big so I ordered some more for tomorrow so il update then
Which bulbs did you go with? From what I understand you have to spend quite a bit to get LED bulbs that produce the correct beam pattern as to not blind others.
