M1K3Y B
When you get the twintercooler will it need mapping again though or will it be effective on the same map?
Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
would it make that noise of gear changes with just a cat back, or is it more from the TBE
It will be fine with the current map but REVO will be releasing a modified map to accomodate these items for the lower running temps so the turbo can boost a bit more.
I would honestly be lying if I could tell you mate. I have not heard some one elses yet in the flesh so hopefully some one with the cat back can advise?
Revo, please come to Slovenia... I need you stage 2 grrrrrr !!
Am I right in thinking you can go stage 2 with the catback and intake? Then stage 2+ is for those with the twintercooler?
Steve, will the FORGE induction kit also be fine? I already have one![]()
