jetex cat back/or no cat
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
got a jetex cat back system
if i remove the mid cat n make it strate through will i get more power
would it be legal to do it i dont know how the law stands on that sort of thing also would it make the mot ok like that:confused:
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
its a cat...back...so u mean remove the mid silencer (the cat is on the downpipe, hence 'CAT BACK')
and that is perfectly legal, and will increase sound, but unlikely to make much more power, maybe a tiny bit
now.. replacing the downpipe and cat (which connects to the 'cat back' system) with a straight through pipe (a decat) would make it illegal and probably fail the mot emissions test
it would also cause a few problems without the right remap
acidstrato
Dec 9, 2004
5,942
yeah thats fine, cos the cats built onto it... i have done so (milltek downpipe and sports/race cat)
downside is that cos they come with a new cat, they are expensive
if u got/get revo stage 2 for example u wont get car problems by removing the cat, but supposedly u will fail the mot, so u either gotta put the cat back on, or go to a 'friendly' mot tester who will ignore it
but it really depends whether u meant remove the cat, or remove the mid silencer of the exhaust system
acidstrato
Dec 9, 2004
5,942
yeah thats perfectly legal but doesnt add up to much...i know supersprint do a straight through pipe on one of their systems
but really the biggest difference should be noise and little performance gain
Beaker™
Slightly Unhinged........
Nov 21, 2005
1,900
C:\UK\Glos
I have a jetexcat back with the mid silencer removed, and to be honest its no louder than other 200+bhp Ibiza's with similar exhaust set ups.
lcjay
433
London
just brought a jetex with the silencer as i spoke to my friend who runs a mot cetre and he said you could have problems getting a mot as they state it must sound like a standard vechcle also they can fail it on incomplete system,hope this helps
lcjay
433
London
only what i was told.if you fancy chancing its your choice.like i say they can fail it on incomplete system too,if they like if it is straight through to the back box
20vtdave
as long as your car doesn't fail on emmissions and has the cat put back on before the mot it can be up to 110 decibels and will be fine, you CANNOT fail for an incomplete system, as long as there are no leaks and all the exhaust rubber mountings are still there, even if it is louder the tester won't take it past fast idle (about 3,500 revs), so if its a good exhaust it shouldn't be that loud. I wouldn't take the cat off as turbo engines are low compression anyway and could cause the ecu light to peck your head a bit as it could read a compression failure.
