Glad you like the bonnet mate, use a little resin over the stone chips and flatten it back you will not see the marks so much then
I've got a "S" badge here in carbon fibre if you want it I was going to drop it off at got boost for u with the bonnet but forgot the badge
Yeah cheers mate :)
Theres a carbon fibre repair place 3 doors down from me work ao gunna pop and see them, if there mega money ill do it like you said cheers :)
Oh was ya lol i would like that yeah lol
Mucka that bonnet is tiiiiddddyyy. one question how is it held down. does it have the standard bonnet catch on it :s rae to see carbon bonnet with standard catch that all.
Cheer mucka
Standard catch and standard mounts ill have to take a pic of the under side
Thinking about using areo catches and removing the catch completely (catch and thing on the bonnet) so i can fit my oil cooler :)
Cheer mucka
Yeah that sounds good. will be good to see what difference the oil cooler will make. Are you removing the standard cooler from the filter housing
I believe it will be easy enough, take filter off undo the nut which holds the cooler in place. Remove the cooler replace with the sandwich plate and away you go. I cant see it being much more complicated. Will have to extend orremove the coolant hoses which go to it.
Yeah only compicated bit is the oil cooler is bigger than the samdwich plate
ive got a shorter union that everyone uses just my one thats been delivered is well short haha
Ill just join the coolant lines lol
Few more bits arrived
Need to get my arse in gear tho haha
Finially got some omp frames for me seats
More side mounts
Injector seals - had a plan but now its changed haha
Storm wash and wipe system as carbon fibre bonnets dont have washer jets haha
Got my shorter threaded union for the oil filter housing to fit my oil cooler
New caliper carrier bolts for the resr tt conversion
Might be selling the whole tt rear brake kit
New calipers
New carriers
New discs redrilled
New brembo pads
New bolts lol
Not sure yet but my new plan needs money so
Bonnet looks great mate intrested to see how them omp frames fit. Do they still have the slider etc..
Thought that's what you would have do think ill stick to custom standard frames as found some seats waiting for the guy Get back to me then just need some cheap polo seats or summit to rob the frames off
