New charge pipe with a welded bead and 25mm and 8mm ports :)
And more SFS hoses
Didnt get much done today as my 18mm deep socket split. Get another tomoz :)
Plan to have it back together by next weekend.
Ordering new rotors tomorrow as hispec will make me a set of replacement AP rotors for £350 delivered in 28 days
Also got a bloody tax reminder through. Maybe the pot holes will be filled in when i pay :)
Did a bit and left a bit tonight
I pressed my bearings and hubs in and the track rod flip bush. Fitted new abs sensors, powerflex front wishbone bushes and ball joints and ball joint extenders
Track rod flip bush. I had the machined within 2 thou of the bush and die grind a lip so they could be pressed in.
Should hopefully help the bump steer
And finially ordered my AP rotors from hipsec as they have 5% off which made them less the 320quid delivered which less than half the price from AP.
make sure your driveshafts don't touch the chassis legs with the extenders on, the rubber counter weight rubs on the chassis leg now and again on mine and there's plenty to go on the coils!
