Ive plumbed my k04 turbo in,
oil feed, oil return, water in, water out... now on the back of the turbo ive found a threaded hole with a tiny hole in the back of it, cant see where it goes to but i took a photo so you could see... as i understood there were only 4 lines to and from the turbo so what is this one?
Also...
Do i NEED to run a secondary water pump with the k04? i heard you must use it or itll bake itself but not sure how true this is?
Thanks in advance
Also...
Thanks in advance
