few options really to be honest mate
you could get a k03 (2nd hand off ebay) for about £150 and have some hybrid treatment. If you want to do this, then give CR Turbos a call
www.crturbos.co.uk. This is what a JBS04 is, nothing special, just a hybrid k03 and IMO some what over priced. So it would be cheaper to source the turbo your self and get a 3rd party to carry out the work
CR Turbos have just done the work on my Garrett GT2x and gave it some hybrid treatment. Fantastic service and I highly recommend them. This is also a direct bolt on to the standard manifold, although this turbo was not cheap
k04 has a different manifold and would require a lot of work with re-routing of other pipes etc and would be quite an expensive route versus the power you would get out of the turbo. Although if you managed to find a written off LCR or TT for example, and you can do it all your self then, again, this could be a viable route. typical K04's with a remap will make about 260-270bhp. hybrid versions make about 290bhp I believe
remember, its not just the turbo, but if you wanted to go down this route, you also have to think about uprated injectors, FPR, fitting, mapping etc, so there is quite a cost in terms of a "turbo package"
hope this helps
