Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
Hey man! I must thank you for the extra bits ? always appreciated, and you'll be pleased to know I managed to find another wiper ?Oh so this is you then lol. Was good meeting you when you came to my workshop to collect the turbo
I'm not going big power, or cupra R power, just want a Ko4 and a little map for it to bring the car up to standard as it were, I'm looking for a fmic or the dual wing intercoolers and obvs the required bits but for now that's about itHey mate sooo I’ve done this swap a few times now in Germany
This is what we are typically swapping over
All of the parts mentioned come from S3,Cupra R, and TT 225hp
Turbo
Turbo TIP
Exhaust mani
Intercoolers
Intake mani with fuel rail and FPR
MAF
injectors
Boost pipes and matching hoses/brackets
Turbo oil pipes
Turbo coolant pipes
Some different vac pipes
Then you can pretty much get it tuned or remapped as a cupra R
Well the ko4 I've bought is lower milage than my ko3, I just want the car to be reliable as it's a daily, obvs 200+hp is right on the ko3 limit whereas the ko4 is capable of more power, I'm currently looking for the exhaust and intake, the turbo itself has all the oil pipes on it and I'm going to do a engine bay tidy and delete all the vac lines that aren't required. It's also if I do want to go bigger power I can as it's already mostly set up.I've never heard of anyone getting a ko4 and a custom map, and not getting all the easier cheaper supporting mods.
Will it even be making use of the ko4 without the bigger injectors etc? Seems like a lot of trouble when you could simply get a stage 1 map and be 200hp+
Fair enough! was just curious lolWell the ko4 I've bought is lower milage than my ko3, I just want the car to be reliable as it's a daily, obvs 200+hp is right on the ko3 limit whereas the ko4 is capable of more power, I'm currently looking for the exhaust and intake, the turbo itself has all the oil pipes on it and I'm going to do a engine bay tidy and delete all the vac lines that aren't required. It's also if I do want to go bigger power I can as it's already mostly set up.
