Hi,
I'm trying to work out a rough idea of how long it will take to do some mods to a Mk1 Leon TDI, I've done some research and trying to fill in the gaps.
This is important because it helps me estimate the garage time it will take, as I need the car and can't just leave it at a garage for a week, and also to help estimate the cost involved.
Here is a list of the jobs and estimated times, which I'm hoping people can give me some feedback on, and correct them where necessary, also if any jobs cross over and reduce overall time:
- Fit uprated SMF clutch: 3.5 - 4 hours
- Fit uprated SMIC, 1.8T pancake pipe, Allard race pipe and associated hoses: 2-3 hours
- Fit uprated turbo (GTB) & PD150 TIP: 3 - 3.5 hours
- Fit uprated injector nozzles: 1.5 - 2 hours
- Fit 11mm injection pump: 1-2 hours??
- Fit PD lift pump: 1 hour??
- Fit 3-bar MAP sensor - 0.5 hours?
- Fit ARP head studs - 0.5 hours?
- Fit 312mm front brake conversion, inc. hubs, carriers, calipers, discs & pads: 2 hours
- Fit 256mm rear brake conversion, inc. hubs, carriers, calipers, discs, pads, trim splash guards: 2 hours
- Bleed brakes: 0.5 hours
- Fit KW Variant 1 coilovers and perform alignment: 2 - 2.5 hours
- Fit uprated engine mounts: 0.5 hours
- Fit S3 upper and lower strut braces: 1 - 1.5 hours??
- Fit digital boost/EGT gauge (from Allard race pipe) - 1 hour?
- Flash ECU with custom remap/tune supplied on portable FlashZilla device from USA & do 'Hammer Mod'/IQ adjustment: 1 hour?
