tomp
Hi all, I've been having some missfiring problems with my 2000 leon 1.8 20vt. So i bought a vag com and these are the faults:
Address 01: Engine
Controller: 06A 906 032 T
Component: 1.8L R4/5VT 0003
Coding: 05510
Shop #: WSC 06441
3 Faults Found:
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-10 - - - Intermittent
17524 - Shareware Version. To Decode all DTCs
P1116 - 35-00 - Please Register/Activate
(looked this up - O2 Sensor Heater Circ.,Bank1-Sensor1 Open)
17522 - Shareware Version. To Decode all DTCs
P1114 - 35-10 - Please Register/Activate - Intermittent
(looked this up - Bank1-Sensor2 Internal Resistant too High)
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 1J0 907 379 AF
Component: ASR 20 IE CAN 0001
Coding: 13404
Shop #: WSC 00000
1 Fault Found:
01276 - ABS Hydraulic Pump (V64)
16-10 - Signal Outside Specifications - Intermittent
Now all i need to do is figure out what this means and fix it.
So any help of whats wrong and how to fix would be greatly appreciated.
Address 01: Engine
Coding: 05510
Shop #: WSC 06441
3 Faults Found:
Coding: 13404
Shop #: WSC 00000
1 Fault Found:
