lambda sensor i'm confused
beezasport
Sold the car to buy a....
EM light is coming on after aprox 100miles when it has been reset with vag-com. The code is as follows.
Control Module Part Number: 06A 906 032 HN
Component and/or Version: 1.8L R4/5VT 0002
Software Coding: 11510
Work Shop Code: WSC 66565
Additional Info: VSSZZZ1MZ3R139454 SEZ7Z0C2042128
1 Fault Found:
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-00 - -
From my understanding the sensor is dead but if it was dead would the elight not come straight back on? This has only started happening after a re-map along with really bad MPG, possibly the map has just finished the sensor off quicker as they do with coil packs.
i did a log of block 30 and 31 holding the revs at 3000 with no load
as follows:
Group A: '030 Group B: '031
Pre-Cat O2 Post-Cat O2 Lambda Factor Lambda Factor
TIME 111 110 TIME
STAMP STAMP
0.36 11 0 0.02 0.844 0.844
1.26 11 0 0.76 0.828 0.844
2.07 111 0 1.66 0.836 0.844
2.97 11 0 2.57 0.828 0.844
3.77 111 0 3.37 0.86 0.844
4.58 111 100 4.18 0.821 0.844
5.38 11 0 4.98 0.828 0.844
6.18 111 0 5.78 0.828 0.844
7.1 111 0 6.6 0.836 0.844
7.9 11 0 7.5 0.836 0.844
8.71 111 0 8.3 0.844 0.844
9.51 11 0 9.11 0.836 0.844
10.41 111 0 10.01 0.836 0.844
11.22 111 0 10.82 0.844 0.844
12.12 11 0 11.62 0.828 0.844
If anyone could tell me how to import these things in, in exel format it would be a big help as i can't find it on search :)
thakns
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
1 Fault Found:
P0130 - 35-00 - -
as follows:
Code:
TIME	111	110	 	 	TIME
STAMP					STAMP
thakns
You need a new lambda sensor
WeeJase
pert
Jun 2, 2001
8,595
can i ask if your lambda was an exchange part?
reason i ask my skoda dealer fitted a lambda ,then when the fault came back,offered a refund,then miraculously it became an exchange item.
WeeJase
pert
Jun 2, 2001
8,595
no idea,this is the issue i have with skoda,one minute they are going to re-fit my old one,next minute i find its exchange item and jason is down 104 smelly one. :(
WeeJase
pert
Jun 2, 2001
8,595
my thoughts exactly. :w4nk: ers.he's getting both barrels from me next week,and skoda uk have already been informed.
