Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
You will need 2 of these
http://www.ebay.co.uk/itm/Black-Sil...arts_Vehicles_CarParts_SM&hash=item27bbdda93d
2 of these
http://www.ebay.co.uk/itm/BLACK-SIL...arts_Vehicles_CarParts_SM&hash=item43a7d46976
2 of these
http://www.ebay.co.uk/itm/63mm-Diam...arts_Vehicles_CarParts_SM&hash=item1e64c383f2
8 of these
http://www.ebay.co.uk/itm/68-73mm-T...arts_Vehicles_CarParts_SM&hash=item2a066aabdb
1 of these
http://www.ebay.co.uk/itm/Alloy-hos...arts_Vehicles_CarParts_SM&hash=item255f8be345
plus what evers needed to support the cooler to the car, Alloy/stainless steel stripped metal, bent & drilled accordingly.
Chrissy
Chrissy the cooler i have and the one in the link has 63mm inletsso no reducers needed. They do two coolers at 600x300x76 1 has 76mm inlets the other has 63mm inlets (like mine)
The crash bar or cross beams will need cutting to fit this monster but its 100% worth it.
Sam can you put a link with that intercooler with the 63mm inlets please, because i can only find the 76mm inlet one. thanks
They don't make the core with 63mm inlet/out let's any more. Only 76mm so you'll need to use reducers. Here is a fitting guild
Thankyou for your help, so will these be ok?
2x Blue Silicone Hose Elbow 90 Degree 63mm 4 Ply
2x 45 Degree Reducers Silicone Elbow Bend Hose - Silicone Rubber Coolant Rad Pipe
2x 63mm Diameter Alloy Bend Elbow 45° Degree Aluminium
1x Alloy hose joiner 63mm 2 1/2" Silicon Silicone hose
and jubilee clips
It's much improved over the standard set up. Infact the improved throttle response is one of the most notable improvments.How's the turbo lag with the Wellycooler? Im contemplating to buy one, but I need to know![]()
and jubilee clips
The pipe work is larger than standard as is the cores in let and out let. Honestly it's all good!Huh? One would think such a big intercooler would give a large turbo lag...
Me to as forge must make the best at that price! Google Wellycooler, or have a look on ASN. don't forget this is a home brew kit and doesn't come win instructions and all the part ready to fit. That costs money!Ive been looking at the forge one for my lcr how come there is such a price differnce?
