A9_SLU
A9 SLU
Nov 22, 2006
114
Portsmouth/Wiltshire
Hi guys my car leaks exhaust gas from the turbo to the down pipe when the engine is under load. I have been told that there is no gasket between the turbo and the down pipe it this correct? I have checked that the bolts are tight.
Has anyone else has this problem?
there no gasket, unless you've had the down pipe off, its machine fit, i've had head gasket changed to had it off and had to fit a gasket!
gasket on the ones i've seen as std
some aftermarket mountings dont run them (like my current turbo to mani) but thats not factory norm tho on a DP
:confused:
mine def didn't have a gasket on it when i took it off, but had to wait 3 weeks for one from seat when put dp back on, they advised putting one on gasket as they are machine fitted at first and don't need the gasket, but once you take it off they say you need to put a gasket on.
sorry i dont, i can see if i can get my bro to find it for you though, he ordered it for me
