Joshhayes
42
Ive recently tried a range of LED number plate lights on my 60 plate bocanegra:
- Cree LED's (used by a friend who removed them from his Nissan GTR because they were so bright.)
- Cheapo eBay LED's from Fizzmo
- 2Twenty LED's from Autobulbs Direct
After trying all of these LED's every one seem to be the same incredibly dim brightness, even dimmer than OEM yellow bulbs.
I have tried them in both housings (one of which is brand new so perfectly clean)
All LED's are error free ones.
I have tried all LED's in both polarities with the same result.
Has anyone else experienced this problem or knows the cause/solution? I have seen a number of posts on here from people with bocanegras all of which seem to be just fine.
Thanks.
Thanks for the replies folks,
I'm going to go ahead and try those ones Troupy, with any luck these will do the trick as I've probably spent around £20 on bulbs with no luck.
Cheers,
Josh
