LED Sidelight FL Leon
Jarre
5,365
11
Stockton-On-Tees
Has anyone found any led sidelight bulbs that will work with a FL Leon, mine is 2010, that don't give an error? Every lot i seem to buy flag an error and it's really bugging me :(
Sam
matty1000kk
71
It appears something electronics wise has changed in the FL model. I have the same problem with LED number plate bulbs. The pair I have appear to work fine in a Pre FL Leon but do not want to play ball in mine. People with the new Golf and A3 are having the same problem. They only way to fool the system at the moment appears to be by using a load resistor.
Aug 20, 2010
495
Gosport. Hampshire
Or turn the warning system of in vag com /vcds
Jarre
5,365
11
Stockton-On-Tees
it's just pretty annoying, i did have some that worked and flagged no errors, however one LED on each bulb started flickering and i can't stop it, so they can't be used!
There must be some bulbs that are capable of not flagging the error system without having to use leads.
