Leon 1P ABS recode problem
tonyuk
Hi all. This is my first post on your forum so please excuse me if I miss something or do something wrong.
Ok, so we purchased a Seat Leon MK2 1.9 TDi 2010 with BXE engine. When we bought the car the engine ECU was fried, wouldn't even connect to vcds so we gave up with that ecu and purchased another ecu kit with identical numbers...When it was all fitted the car started instantly and drives perfectly. Problem is we have lights flashing all over the dash and VCDS shows a long code of all 0000's and have no idea what the long code possibly be.
This is a copy of the VCDS we got when we scanned the car. Ignore the Mass flow sensor fault as it was unplugged at the time of the scan.
Tuesday,08,November,2016,13:56:20:49450
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 16.8.0.3
Data version: 20160803 DS255
VIN: VSSZZZ1PZAR016711 License Plate: KV10
Mileage: 146910km-91285mi Repair Order: 000011
Chassis Type: 1P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 52 56 62 72
VIN: VSSZZZ1PZAR016711 Mileage: 146910km-91285miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 021 SC HW: 03G 906 021 AN
Component: R4 1,9L EDC 000SG 1438
Revision: --H11--- Serial number:
Coding: 0050071
Shop #: WSC 06401 785 00200
VCID: 72EBB0AE6D6E0BD2A6-8026
1 Fault Found:
000258 - Mass Air Flow Sensor (G70)
P0102 - 000 - Signal too Low
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 146916 km
Time Indication: 0
Date: 2016.11.07
Time: 21:54:53
Freeze Frame:
RPM: 1029 /min
Speed: 0.0 km/h
Load: 0.0 %
Duty Cycle: 64.7 %
Bin. Bits: 11000100
Mass Air / Rev.: 455.0 mg/str
Mass Air / Rev.: 0.0 mg/str
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 00000000000000000000000000000000000000
Shop #: WSC 04941 000 00000
VCID: 78FF8286CB12618298-802C
4 Faults Found:
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 112
Time Indication: 0
Date: 2016.11.07
Time: 22:55:19
Freeze Frame:
Count: 3
Count: 0
Count: 20992
Count: 195
Count: 41472
Count: 0
Count: 0
Count: 0
01435 - Brake Pressure Sensor 1 (G201)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 112
Mileage: 146916 km
Time Indication: 0
Date: 2016.11.07
Time: 22:55:02
Freeze Frame:
Count: 3
Count: 2
Count: 28672
Count: 279
Count: 41472
Count: 0
Count: 0
Count: 0
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 112
Mileage: 146916 km
Time Indication: 0
Date: 2016.11.07
Time: 22:55:02
Freeze Frame:
Count: 3
Count: 2
Count: 28672
Count: 295
Count: 41472
Count: 0
Count: 0
Count: 0
01423 - Lateral Acceleration Sensor (G200)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 112
Mileage: 146916 km
Time Indication: 0
Date: 2016.11.07
Time: 22:55:02
Freeze Frame:
Count: 3
Count: 2
Count: 28672
Count: 270
Count: 41472
Count: 0
Count: 0
Count: 0
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5P0 907 044 P HW: 5P0 907 044 P
Component: Climatronic H15 0602
Revision: 00001001
Coding: 0000000002
Shop #: WSC 99999 1023 2097151
ASAM Dataset: EV_Climatronic A01006
ROD: EV_ClimaAutoBasis_SE35.rod
VCID: 3D715392ACB084AA8B-8068
No fault code found.
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 085 HW: 5K0 937 085
Component: BCM PQ35 B+ 008 0019
Revision: BB008001
Coding: 46180A3C9005B0904680008091000004050100A8425D81605C8040000000
VCID: 70EFBAA6A36239C250-8024
Subsystem 1 - Part No: 1P0 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 13011 22 0611
Coding: 00DB90
Subsystem 2 - Part No: 1P0 951 171
Component: Innenraumuebe 010 4971
Coding: 000000
Subsystem 3 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Coding: 000000
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 J HW: 5N0 959 655 J
Component: J234__A0E VW10 HI 1916
Revision: 20013000 Serial number: 003E2PS3QME8
Coding: 0012357
Shop #: WSC 06402 785 00200
VCID: 44872676075AF562C4-8010
Subsystem 1 - Serial number: 6332MTS658493309
Subsystem 2 - Serial number: 6342MTS603093309
Subsystem 3 - Serial number: 6351HTS65PUN76KR
Subsystem 4 - Serial number: 6361HTS6UMBO76KJ
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CQ HW: 1K0 953 549 CQ
Component: J0527 853 0111
Coding: 0000004
VCID: 0305E56A42D4325ABD-8056
2 Faults Found:
00888 - Wiper Switch for Intermittent Operation (E22)
014 - Defective
01044 - Control Module Incorrectly Coded
000 - -
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 1P0 920 910 C HW: 1P0 920 910 C
Component: KOMBI H17 0109
Coding: 410A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
VCID: 295997C24838080AD7-807C
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H16 0233
Revision: H16 Serial number: 4520K101080825
Coding: E9807F06000212000203
VCID: 69D9D7C240B8C80A17-803C
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H17 0109
Serial number:
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Component: SG EXT.PLAYER H13 0090
Revision: A1001003 Serial number: 7667744272
Coding: 020000
VCID: 26439CFE51262772FA-8072
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 1T0 959 701 AG HW: 3C0 959 793 A
Component: TUER-SG FT 002 0312
Revision: 12101005 Serial number: 0000075090
Coding: 0012B0
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide.rod
VCID: 7CF79E96F72A4DA2FC-8028
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 704 AF HW: 1K0 959 794 S
Component: J389__TSG-HR 006 1401
Serial number: 00000004533600
Coding: 000290
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 65 3001
Revision: 00H17000
VCID: 31697FA2A8E870CA1F-8064
1 Fault Found:
03803 - Steering Angle Sensor for Steering Aid
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 146916 km
Time Indication: 0
Date: 2016.11.07
Time: 21:41:41
Freeze Frame:
Battery Volts: 11.9 V
DD
Temperature: 10.0°C
Count: 3
Steering Angle: 0.00°
Count: 0
SteerAng n.Init
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 1T0 959 702 AC HW: 3C0 959 792 A
Component: TUER-SG BT 002 0312
Revision: 14101005 Serial number: 0000129700
Coding: 0012B0
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide.rod
VCID: 79F98782F818788AE7-802C
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 703 AF HW: 1K0 959 795 S
Component: J388__TSG-HL 006 1401
Serial number: 00000004530133
Coding: 000290
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1P0 035 153 HW: 1P0 035 153
Component: Radio H03 0008
Revision: R0000000 Serial number: SEZAZ1K7836678
Coding: 0101040002
VCID: 62CBC0EE7D8E9B52D6-8036
End-------------------------(Elapsed Time: 02:38)--------------------------
Any help is appreciated in trying to figure out what this long code could be to get the lights off the dash.
Many thanks
Tony
Oct 15, 2020
18
Birmingham
There will be a nice drink in it for whoever comes up with the code :)
Did you have any response or joy sorting this.
I have a similar issue, I changed the steering Control Module because I couldn't get any lights on my dash. Now its working again starts & drives but I have the annoying beeping & flashing break light & ABS also the turn signal does not self cancel??
My scan is telling me the ABS is not coded & it displays as 000000
Oct 15, 2020
18
Birmingham
Would I be correct thinking the code is the serial number from the Control Module ?? I still have the old module so I will try a few ideas tomorrow but any help i can get will be greatly appreciated.
Thanks in advance.
Rusty2k
717
142
Assuming it's the same model of ABS module then you just need to copy the coding from the old one to the new one, yes.
Oct 15, 2020
18
Birmingham
OK thanks for that replay... It was the steering control module that I changed. & yes the serial numbers are different before I start changing things I was hoping someone had the correct answer for me.
I had to change it because all the ignition lights would not light up so the ignition would not progress to stage 2 & ignition. Now the car starts & drives but i have the annoying beeping & flashing ABS.
Oct 15, 2020
18
Birmingham
I've entered a random code today 0023238 and it was accepted by the ABS BUT it then said its incorrectly coded... The beeping & the red handbrake light has stopped flashing but the code is not right and the ABS & ESC is still on
Rusty2k
717
142
What are you using to scan / code with? It might be helpful to see full details from a VCDS auto-scan or something similar.
Oct 15, 2020
18
Birmingham
Thanks for the reply here's my VCDS scan
  • Scan-VSSZZZ1PZ7R021425-20201224-1212-179660km-111635mi.txt
