OK - reporting back:
Needle sweep can be done with Carista.
You can turn off the option to have flashing hazard lights under heavy braking.
I can't see any option to change the MFD digital speedo to mph, changing the area to "Australia" converts all your units to km and nothing else.
edit: This is on a facelift 59 plate Cupra.
Needs to be set to "rest of the world"
http://www.seatcupra.net/forums/showthread.php?t=333131
This is what I couldn't get to work on my Supercopa via VCDS
i have the VCDS wire bought from ebay (£12 or so) and the software downloaded on a laptop (FREE) and i can do diagnostics and everything. i even set the needle-sweep on my 2011 leon.
i dont use it often so i guess a little notebook and a wire does the trick. i guess if you want to play about with the settings often the Carista thing will be handy.
