Try robthebubble he makes drls to fit straight on cupras with K1 kit... I got some off him and they smart
They are easy to fit...all you need is a screwdriver, scissors, wire coat hanger and a ratchet set (although not necessary but makes it a bit easier).
The hardest part is making them!
Yes, I can make them. New vents, cables, Dimmer control unit, full fitting guide etc. Not sure how many posts you need to make before you can PM...should be under the FAQ section?!?!?
do they all face forward perfect or some of the lower ones on a slight angle up as the trim curves at the bottom
