Hi there, I have a 2007 leon cupra 2.0 tfsi K04, I had my car plugged in today as ive had a engine misfire problem occur last night, anyway there was 2 codes on the system and one is regarding the oil temperature sensor, see below:
000406
P0196 - ENGINE OIL TEMP SENSOR (G8) - IMPLAUSIBLE SIGNAL
Does anyone know where this sensor is????
I recall that most VAGs only have this fitted when they has a oil level sensor fitted to the sump, which the CUPRA BWJ engine does not have fitted from the factory!
The question is does this engine have a sensor or is the ECU looking for something that was never fitted and why is it not aware of this??
Any help is much appreciated, if it does have a sensor can anyone point out where it is located as I have another vehicle I can swap it with to test it.
000406
