Leon Cupra R ESP Brake Pressure Sender G214 Wiring
Craigb233
Hello Everyone,
I have a LCR ecu in my Volkswagen Corrado and want to attempt to get the ABS unit working too as its a bit too much of a handlefull all the time.
I've had a search around the net for weeks now and am unable to locate where sensor g214 is wired into the teeves 60 abs controller. I have the golf mk4 wiring diagram but it completely misses this sensor.
I have sourced the controller and brake servo sensors. I have a pigtail loom front a different teeves unit so cant even guess. I need the steering angle sensor and direction box sensor still. But am holding off on these currently till I work this out. Otherwise ill go down the ASR route. The TT diagram has both sensors but is completely different I believe unless someone corrects me?
Any help is appreciated. Apologies for this being my first post but its currently driving me mad.
Regards, Craig
mty12345
4,133
691
bristol
Here you go mate, hope this is some help for you.
[/URL][/IMG]
Craigb233
Thats brilliant, worryingly I had that location for the other pressure switch g201. Any chance of the location of g201? Sorry to be a pain.
Regards, Craig
mty12345
4,133
691
bristol
Ho worries :) Here you go. The other two items shown in the diagram, but missed off the top of the screenshot are:
G44 Rear right speed sensor
G46 Rear left speed sensor
[/URL][/IMG]
mty12345
4,133
691
bristol
There you go buddy, did the whole diagram for you just incase any others are different.
You're welcome, good luck with it.
