Hello folks,
not long had the mk2 fr tdi and already having some niggly issues with it,
the cars is standard engine wise (not for long) with 73k on the clocks by the way,
basically my issue is-
when driving around mainly in 2nd gear it sometimes wont come on boost.........the revs will increase but i dont get no boost from the turbo to help me along,
if i get going in 2nd the turbo normally comes in just after 1.5k but as i said it sometimes doesn't come in at all,
if i let of the throttle to let the rev's drop then jump back on the throttle again the turbo will come in............ sometimes it works fine but then other times it wont work at all?
it does it pretty regular in 2nd but not so much in 3rd-4th-5th etc etc (although it will still sometimes do it)
so far ive done the following which hasn't helped-
changed the diesel filter
changed the airbox filter
checked for boost leaks (all good)
cleaned the air flow meter
had it on a friends diagnostics machine........said something about a grounding alarm fault (cant remember exactly)
there's no dah lights on the dash or anything so im kinda stumped?
anyone else had this issue? im thinking it could maybe be the boost pressure regulator???
any help would be greatly appreciated folks
