Hello
Just wonderind if anyone has a step by step guide on how to remove the double din headunit in a leon?i know that you need four removal tools two at the top and two underneath the display. Any advice and guides?
if its early mk2 its release keys,later models were by removing the front and unbolting it
the release key method was on youtube or something like that
Hey guys just thought i would let you know i got it sorted before you guys replied just tried and it came out alot easier than i thought it would! Thanks for your help!
mk2 leon has no ignition feed,either both red and yellow from the stereo to the red wire on your radio loom (car end) or if you do want ignition either an ignition generator (only works with engine running) or a canbus interface,allows turning on when key put in and also has other features such as illumination,handbrake,speed pulse,etc
