• Hi Guest There will be essential maintenance on the server on Monday 10th November from 5am meaning the website will be offline for a period of time. We will do everything to ensure the downtime is kept to a minimum.
stepp
20
10
Guys
I have searched....my leon has 18" wheels, i can get hold of space saver really cheap, its 18" but it measures 2cm bigger than my wheels/tyres.
Is this OK to use? i can see you can go slightly smaller but can't find anything saying you can go slightly bigger.
Bit of a noob when it comes to tyres size !
My tyres are 18" 225 40 18
Thats why its slightly bigger then 40 v 70............anyone know if its still OK to use it ?
Something is strange there. Your tyres should have a 90 mm (225 x 40%) sidewall while the spacesaver should have a 87.5 mm (125 mm x 70%) sidewall (wheel size is the same).
I know the calculated sidewall heights are theoretical and there are differences between tyre brands but a difference of 12.5 mm sounds like a lot (I'm assuming that your measurement is diametral rather than circumferential).
How did you measure your tyres? Did you do it without weight on the tyre?
Reactions: stepp
A 225/40-18 has an overall diameter of 25.09 inches. A 185.70-18 space saver is 24.89 inches, so less than 1% difference. Fine as a spare.
The space saver should be fitted as a rear wheel and speed then limited to 50mph.
Reactions: stepp
Your tyre sizes are correct with 225 40 18 on the car and 125 70 18 on the spacesaver.
These are the sizes I have on my Leon.
Reactions: stepp
