Logs
ross p
Back at last....
Jul 13, 2007
467
Glasgow
www.firstrespondernm.co.uk
Hi all
Done a scan and got the below log, can you advise please?
Fault code scan
Thursday,21,April,2016,18:43:50:23326
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
www.Ross-Tech.com
VIN: VSSZZZ1PZ8R040088 License Plate:
Chassis Type: 1P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: VSSZZZ1PZ8R040088 Mileage: 163760km-101755miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 03G-906-018-BMN.clb
Part No SW: 03G 906 018 DT HW: 03G 906 018 DT
Component: R4 2.0l PPD1.2 G 4352
Revision: --H42--- Serial number: SEZ7Z0G3868324
Coding: 0050072
Shop #: WSC 02111 476 88184
VCID: 7AFFADB4358447EE30-802E
1 Fault Found:
008194 - Particulate Trap Bank 1
P2002 - 006 - Efficiency Below Threshold - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 5
Fault Frequency: 9
Reset counter: 40
Mileage: 163698 km
Time Indication: 0
Date: 2000.00.00
Time: 22:20:57
Freeze Frame:
RPM: 2432 /min
Torque: 64.0 Nm
Speed: 0.0 km/h
(no units): 2.0
Pressure: 0.0 mbar
Lambda: 30.5 %
Time: 4492.8 s
Readiness: N/A
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0006786
Shop #: WSC 04941 785 00200
VCID: 73E1809012EE36A673-8026
2 Faults Found:
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
003 - Mechanical Failure - Intermittent
008 - Implausible Signal - Intermittent
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1P0 907 044 B
Component: ClimatronicPQ35 011 0602
Shop #: WSC 00000 000 00000
VCID: 2B5158F08A5E2E66FB-807E
No fault code found.
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000005130038
Coding: 81880F2F00041000431D00000000000000007F075C400000000000000000
Shop #: WSC 18434 020 328969
VCID: 71ED8A9868F204B681-8024
Subsystem 1 - Part No: 1P0 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 190907 022 0601
Coding: 00056208
Shop #: WSC 18434
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 L HW: 3C0 909 605 L
Component: R5 AIRBAG VW8 030 2522
Revision: 12030000 Serial number: 003B0PK74TBO
Coding: 0021045
VCID: 2F694CE0BE465246D7-807A
Subsystem 1 - Serial number: 6332MSME2F225843
Subsystem 2 - Serial number: 6342MSME2F233545
Subsystem 3 - Serial number: 6351HTS61CG81K37
Subsystem 4 - Serial number: 6361HTS61CG4AME6
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
Component: J0527 636 0070
Coding: 0002042
VCID: 010DDA585852143671-8054
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 005 0060
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1P0 920 925 A
Component: KOMBIINSTRUMENT VO3 0424
Coding: 0000401
Shop #: WSC 00947 210 60131
VCID: 2D5556E8B44A2056E5-8078
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K078210A1C
Coding: E9807F060002020203
VCID: 306B4F9CA3784DBECE-8064
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VO3 0424
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 G HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1130
Revision: 31008001 Serial number: 00000562978528
Coding: 0000688
VCID: 3B7168B07A3EBEE66B-806E
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.142 H08 1901
VCID: 36677984411C638E94-8062
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 008000005183CC7F0000850560085F86F07C00
VCID: 0301D050424E062663-8056
Subsystem 5 - Part No: 1P0 951 171
Component: Innenraumueberw.010 4971
Coding: 00000000
Shop #: WSC 00947
Subsystem 6 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 7 - Component: NGS n.mounted
2 Faults Found:
01135 - Interior Monitoring Sensors
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 75
Time Indication: 0
00893 - Switch for Trunk Handle (E234)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 4
Fault Frequency: 2
Reset counter: 46
Mileage: 163016 km
Time Indication: 0
Date: 2000.00.00
Time: 12:29:04
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 G HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1130
Revision: 31008001 Serial number: 00000547978604
Coding: 0000688
VCID: 3C736BAC7F30B9DE62-8068
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1P2 035 186 A
Component: Radio BVX 0006
Coding: 0040424
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 N HW: 1K0 959 795 H
Component: J388 TUER-SG HL 1108
Revision: 11006001 Serial number: 00000002159877
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 N HW: 1K0 959 794 H
Component: J389 TUER-SG HR 1108
Revision: 11006001 Serial number: 00000002237612
Coding: 0000144
End-------------------------(Elapsed Time: 01:40)--------------------------
SWANSWAY CUPRA Dealership
