Discovered this afternoon whilst cleaning the Ibiza that my passenger side wing mirror is loose and rattles around quite a bit. Does anyone know how to tighten up the fitting? I'm hoping it won't require disassembly of the door or a visit to the dealer
If you fold the mirror up there is a rubber gasket underneath with a slot in it , through the slot you can put a torx key into it to tighten it up (hopefully)
Mine did too, just tighten the torx, (your key will do the first bit of it, enough to get it home and not worry about it falling off, if you've not got a torx to hand)
