Loss of power after clutch & flywheel change
BassMoore
21
Oxford
Hi,
I recently got the clutch and DMF changed on my MK4 Ibiza pd130 TDI stage 1, and now it feels like i have lost a bit of power. But i am not sure whether this is because it feels so different and i am just not getting used to it.
It has been replaced with LUK parts and its after i change lower gears there is more "turbo lag" than before... Could this be due to the clutch? So i change gear then i have 2-4 seconds before it kicks in.
Thanks in advance..
bryn2101
Had same problem
If its same as my problem then its the air flow sensor that's gone and will need replacing mine cost £90 and £60 labor my car is the 1.8T Cupra
attila_tdi
384
Hampshire
Could be a hose or vaccuum line not clipped in correctly. Its very difficult to tell unless you run a scan on vcds. If you have access to this software the run a log accelerating through the gears. You sould be able to compare specified and actual boost pressure.
Let me know if u want to know more, i've been meaning to write a how to but not had time
