Dec 23, 2021
8
Hi, I hope someone is able to help me. Basically the issue is in the subject. When I turn my full beam on my low beam lights turn off, when I turn full beam back off then the low beams come back on. They are both working so it makes me suspect a coding issue.
I have done the auto lights retrofit and the issue has arisen since then. Everything else seems to work OK. The only coding I did after the physical switches change was to change rlhsensor to installed. I have done the fog lights activation on full beam just to give me a bit of extra light as it's quite dim in the near distance due to low beams turning off.
I have searched but not found any similar topics. Any help is greatly appreciated.
