Just wondering if anyone has had their lower suspension arms replaced., is it a big job and how much it costs roughly? Cheers
Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
Its actually just as cheap to replace the whole arm, they have 3 bushes each side so replacing the arm changes all 3 bushes instead of changing just the balljoint for example.
It also is less labour to replace the complete arams, as you remove & refit instead of removed, press bushes out/in then refit.
You can get a pair of complete arms for circa £60, labour is an hour to an hour and a half for both max, they take 20 minutes each in the real world max.
I been quote approx £400 fitted so I'm guessing they are not the cheap ones . Thanks for the offer of the second hand ones but I'm looking for new cheers though
Dave @ SERE does new LCR wishbones for £125 each with bushes but without the balljoint (£31.85 ea) so for new bits you'd be looking at ~£315 before fitting![]()
You can get fantastic pattern parts for much less
