Manual to dsg swap
raheem7869
9
Hi guys just wondering if I could a little help from yous I already own a seat Leon 2010 cr170 manual have owed it for number of years it’s due for clutch flywheel change was wondering what is required to swap the manual for dsg and how hard is it thanks
Rusty2k
710
133
if you have a donor CR170 DSG scrapper you could get all the parts and wiring looms from in one go then it would be possible, though I'm honestly not sure if it would be worth it vs. the cost of selling up and buying a DSG model instead.
If you didn't have access to a donor car then, IMO, it's not worth attempting.
Off the top of my head you'd need the following (may not be a complete list...)
Gearbox, including mechatronics (gearbox code LTD is the correct one for the Leon CR170)
Gearbox to chassis mounts
Flywheel
Driveshafts
Cooling system plumbing for DSG oil cooler
Engine bay wiring loom
DSG shifter assembly and selector cable
Wiring loom for shifter
DSG gearknob and gaiter
Steering wheel paddles
ABS unit that can be activated for hill hold (if the current one doesn't provide this)
Foot pedal assembly for automatic models
VCDS or similar would be required for coding and adaption too.
raheem7869
9
Sounds about right how much for the donor car and where about are you
Rusty2k
710
133
I don't have one for sale... just giving you an idea of what would be needed.
raheem7869
9
Oh thanks for that I think that would be the best idea having both of them along side to see what goes where thanks agin
fozzybear
middle aged speed freak
Feb 4, 2006
317
19
halifax,west yorks
to be realistic it isn,t worth even thinking about as by the time you,ve done you could have bought one cheaper....why dsg anyway..
more fun with gears and better in winter as autos are terrible in snow/ice....you,d be mad to change...if still want dsg...I suggest either trade in while still have clutch,or if knackered repair clutch then trade for dsg….I would however find people who have got dsg and ask them how they did over winter with bad snow before you leap ….
