Mgtf ap calipers
Jon Olds
Newbie
Mar 3, 2005
76
Different. I have had both on the bench, still have the mgf ones, nice kit and cheap..
But not so adaptable to fit
Jon
747_727
1,113
Essex
Jaz281288
277
Where can I get the spring plates that sit behind the pins and push on the pads I carnt find them anywhere Even on ap website
IBIZA CUPRA TDI 244bhp
747_727
1,113
Essex
I read the pins are the same so I assume those spring plate will fit too but I'm not 100% sure. You could ask them for the dimensions and see they are the same. They are cheap and might be your only option if you need some.
Jaz281288
277
they look like the black plates in the pic sorry it's not a clear pic
mjstokes85
Diesel Power
Nov 14, 2005
1,519
26
40
Long Eaton
I have been in touch with AP racing to try and blag some free pins etc. Unfortunately they won't send me anything free, BUT they have given me all the correct part numbers for the pins etc
Dear Sir
Caliper # CP6607-8S0:SEA & CP6607-9S0:SEA
AP Racing does supply Seat with pad pin kits , but if you don’t have a local Seat dealership close by or they are unable to obtain them for you, then you can order pins from one of our official distributors listed on:- www.apracing.com
If you are based in the UK try Circuit Supplies, they hold these pins in stock.
Pad retainer Pin # CP7600-109 (95mm long)
Pad anti-rattle clip # CP6607-124
(When refitting the pins smear the split collet with a light film of copper slip, that will help to reduce the effects of road salt corroding the steel collet into the alloy caliper body).
The disc and pads are Seat parts, but if you wish to improve the braking and also reduce pedal travel then change the pads to Ferodo DS2500: - APR pad set part # CP6600D50-DS2500. Circuit Supplies can supply these as well.
Regards
Peter Collen
I have emailed Circuit Supplies http://www.circuitsupplies.com/ap.htm and asked for a price on the anti rattle clips. The correct pins can be bought here - http://www.part-box.com/product_info.php?products_id=36555
