Mib2 Standard for June 2022 (1910) (not for facelifted 2020 models that are Mib3)
Tell
It's that time of year again if you like to keep your built in Mib2 Standard maps up-to-date. The release is available on VW servers applicable with the workaround:
Normal form applies, don't delete the SD card without taking a copy of it, read the resource section on the workaround else it won't work 😍. Watch out for Mac's etc.
Apr 24, 2022
I have 1810 as the last update on my 67 plate Ibiza, can I update to version 1910 without losing the car play functions
Tell
You must take a copy of the SD card then follow the workaround instructions of moving that overall.nds file. Use CleanMyDrive on the SD card if using a Mac. You just delete whats on the SD after taking a copy. Dont format it, more risky. Unzip to the HD, copy over to SD card. Then copy the old overall.nds file back into position. Bobs your Uncle.
This month there will be the November release. No sign of it yet.
Tell
November 2022 release is now out see
