Misfiring issue P0303
paul6316
White K1
Oct 16, 2007
297
Engine management light came on after a bit of hard acceleration and then car (K1 2008), started to misfire. Quick scan brought up P0303 so I changed all four coil packs and expected it to be fine but it wasn't. Car was running really badly and using a load of fuel so took it to my local garage who couldn't solve it and put it down to a faulty Ecu so they got that checked but its fine. They are not very hopeful of finding what it is and say I should go to the main dealer.
Car gas a Revo stage 1 map and was fine up until this ECU came on.
Any suggestions before I bite the bullet and go main dealer?
Ghostface
87
29
It seems to be cylinder 3 so you've tried coil pack, not spark plug? Try that if that's not the issue get injector 3 looked at. A few threads I've read people's misfire mostly ended up being the injectors dirty or faulty.
paul6316
White K1
Oct 16, 2007
297
reports back from the garage are that it is most likely the injector and they are stripping it out to confirm. They have attempted to source a replacement but have been told that they are on back order at TPS with no due date!! Anyone have the part number or know where i could find it?
