Andrix Active Member May 26, 2013 5 0 London Jun 4, 2013 #1 hiya everyone, planning to fit 15mm wheel spacers for my Cupra... Is it good idea or no?
blackcupra180 Active Member Aug 4, 2009 513 2 fife Jun 4, 2013 #2 Good idea Sent from my iPhone using Tapatalk
Andrix Active Member May 26, 2013 5 0 London Jun 4, 2013 #3 and what about vehicle stability and control, is it gonna be affected?
RaviR50 Active Member Aug 15, 2012 2,425 5 Southampton Jun 4, 2013 #4 so long as they are hubcentric you shouldn't be worried will probably be worth getting some longer wheel bolts though
lcr.kenny Active Member Apr 20, 2013 64 0 Jun 4, 2013 #5 Ive got 20mm on the rear of mine and its fine
Exe_LeonCR Exeo ST Feb 12, 2012 284 0 Devon Jun 4, 2013 #6 15mm hubcentric on mine are a good fit with longer bolts
B47t0n Active Member Nov 6, 2010 161 0 Jun 4, 2013 #8 I have 15mm on rear looking to get 10mm for fronts
blackcupra180 Active Member Aug 4, 2009 513 2 fife Jun 6, 2013 #9 Andrix said: and what about vehicle stability and control, is it gonna be affected? Click to expand... Well mines are 15mm all round. I never noticed any difference in the way the car felt but it makes it look better and well for me that's everything. Sent from my iPhone using Tapatalk
RaviR50 Active Member Aug 15, 2012 2,425 5 Southampton Jun 6, 2013 #10 if anything it should make it more stable and better in the corners
Captain Cupra Nov 16, 2007 1,223 1 Portchester, Hampshire Jun 6, 2013 #11 15mm hubcentric h&r is the only way forward
Captain Cupra Nov 16, 2007 1,223 1 Portchester, Hampshire Jun 6, 2013 #12 Maximum I can run with Yoko AD08's on the rear and 8mm on the front...
LEE69 Stage 2 Revo'd Dec 10, 2004 21,250 73 C\UK\Devon\Torquay Jun 6, 2013 #13 I use 20mm mm bolt to hub ones, allows you to use the standard wheel bolts and lockers.
Brettyboy Active Member Jan 21, 2012 2,594 4 Exeter,Devon Jun 6, 2013 #14 http://www.seatcupra.net/forums/showthread.php?t=306634&highlight=spacers
