mk4 vacum pipe
jonnysmith199
hi guys this my sound stupid but i dont know my way an engine. right i need to find my vacum pipe on my mk4 4 ibiza fr ive been told that its behind the brake vacum pump problem being i dont know wot my brake vacum pump looks like either. was wondering if any off u guys cud give me a hand finding this pipe. pictures would be a great help
cheers in advance
jonny
muddyboots
Still hanging around
Oct 16, 2002
5,739
There's load of vacuum pipes on TDIs.
Any idea which one you might be looking for (ie what it connects to, or controls) ?
muddyboots
Oct 16, 2002
5,739
Well the brake vacuum pump is situated on the end of the engine.
If you're stood looking at the engine with the bonnet up, it's on the right hand end at the top of the engine, you'd have to remove the engine cover (if they still fit them!) to see it.
jonnysmith199
its to connect my dump valve the instructions just say to disconnect the vacum pipe locasted at the back of the vacum brake pump
Sisson
Club member
Aug 18, 2005
1,662
Derbyshire
Ha..
Pretty sure the dump valve that "was" in my old Ibiza TDi was connected to one of the pipes coming off that black box.
ring Dervdoctor and see if they can help ya.
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
i have pics hosted og this ( helped a fella fit one of these)
il hunt it down , its on RHS of engine below the main engine plug
EDIT
i cant find it and its getting dark for a pic , so nah nah nah , its easy found tho , remove the engine cover , and probably the intake to the airbox . and the hose is on the low RHS of the engine going to the bulkhead , thats the one you want , make sure you tighten everything well up , because if that pipes splits you lose the brake servo = bad day
