Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
Stop guessing on how far you're going on £20. Fill the tank to the brim, reset the trip counter and run a tankfull. Then fill up to the brim again and see how much it takes to fill up again, then use that amount and the miles travelled to work out your MPG. Filling up with £20 and driving til the light comes on will be very inaccurate.
You'll be lying to yourself too
As if only put £20 in, you'll get a higher mpg, because the car is lighter than if you did a full tank. Makes a huge difference in weight having a full tank to having half tank full. Why do you think in F1 they have lots of boffins working out to the exact ml how much fuel to put in (which will be even more crucial next year in f1 season!)
Anyway, strayed a bit away from the point, but to get accurate mpg reading fill it to the max, reset odometer, then get the needle as low as you dare to go (I've managed 80miles on the yellow light before I chickened out!), then work out the mpg! Easy!
Hello again as some of you are aware recently bought a leon mk1 tdi110 and recently put £20 of regular diesel in it and have covered around 130miles now and only have just over the 1st indication left fuel light is on I was expecting alittle more miles than this, does it sound low?
cheers.
why can't people just work out their mpg instead of quoting x miles for £x and £x.xx! I pretty much always average 45 mpg, regardless of how the mix of my driving changes, although i do predominantly motorway miles.
