Leonfrdiesel184
158
37
Hi everyone I just wondered if you can fit genuine mudflaps without removing the wheels ? Plus anyone know the cheapest place to get them from thank you so much
I’ve not fitted these, but assume that you just need to remove some of the torx screws holding the wheel arch liner in place - will just need a 90 degree torx set similar to an Allen key set. Made easier on the front by turning the wheel to full lock to give you additional room.
Rears have different profiles for standard/FR modes and 5dr/ST so make sure you get the correct ones.
OEM ones are listed here - they have the part number in the listing, so you can search the web for a better price too:
Reactions: Leonfrdiesel184
Have not fitted them - but would suggest it would be much easier if you remove the wheel. Some you can barely get your hand between the tyre and wheel arch.
Thank you everyone for the replies.
I got some genuine ones from ebay which luckily were on offer and cost me 60 delivered for front and rear.
I can confirm that I fully fitted them without removing any wheels at all. The fronts I just turned the wheel on full lock and the rears I used a mini wratchet set and got the rear torx of no problem.
Thanks for everyone's help and made a good difference stopping crap going up the car
