Having an issue with my car ATM where it idles rough and then cuts out, or goes into limp mode on boost before cutting out.
Scanned it last night and got all the fallowing codes:
P1289, turbo bypass valve short to ground
P1421, sai valve short to ground
P1435, sai pump short to ground
P1117, ho2s sensor bank 1 sensor 2 short to ground
P1114, ho2s sensor bank 1 sensor 2 resistance too high
P1425, tank ventilation short to ground
P1225, injector 1 short to ground
P1226, injector 2 short to ground
P1227, injector 3 short to ground
P1228, injector 4 short to ground
P0102, maf low input.
Only things to change on car recently are n249 bypass and fpr swapped.
Any help welcome as I'm lost
Phil
Phil
