Need advice !!
Jun 23, 2022
hello all I am new to this so sorry if this has been asked before and help would be welcomed.
Admin, please delete if not allowed.
I did have this up for sale as a spare/repair but I am just getting time wasters.
recently brought my 3rd Mk1 150PD. It recently thrown up x4 fault codes they are all open circuit/short circuit to ground they are:
fuel pump relay
EGR vacuum regulator solen val
Intake manifold flap change over valve
Fan one control circuit
Westgate bypass regulator valve.
I can only assume they all share the same ground? has anyone had this before if so how was it fixed i am really scratching my head with this one.
It is smoking alot and obviously running in limp mode. It starts up fine, I have changed the fuel pump relay and thats not done anything.
any help is welcomed, thanks in advance.
mty12345
4,088
668
bristol
fuel pump relay
Take the battery tray out and have a look around there for any grounds. undo any you find and clean them up with a wire brush or similar
