The lowering of yours is look for springs or coilovers with least amount of drop. I've seen some coilovers that are 20mm front 30mm rear. Much lower and may have issues with speed bumps.
Sent from my SM-G955F using Tapatalk
where can I get them from, have a splitter on now so 20mm is better for me than 30mm, but it may be still a issue with the splitter
These are a cheap set with damper adjustment. But If search will find a set. But will do 20mm front 30mm rear.
think 20mm will be ok with front splitter on? that the reason I haven't lowered it as yet
Yeah should have loads clearance and with rear going 10mm lower will lift front bumper slightly. Sea saw effect on front wheels.
Had few family problems so not get much done. Rubbed down and primered it then sprayed red. Now gonna mask up some bits and spray black.
Thinking about doing all tubing parts black and leave red where the arms attach
Red on its own a bit much lol
think your right, I went to order some of them BTCC alloys you showed me, I told you I was looking at changing my standard BBS one.
There's no UK stock and they don't know how long it would take to get them that's if they can:cry:
They are enquiring for me
That's depressing. Can try gum tree for second had set n sometime new set on there. Or ebay may have some just keep searching you will find them eventually
Here a set on eBay item number at bottom just search that number. They need refurbishment usually £50 a wheel. And couple tyres.
3 months ago there were new full sets on eBay and gumtree. I'll see if can find the listing, then you can message them n see if still got them.
My phone history not go back far enough so I'll look on pc when finish work in few hours.
No probs fella
Nice...
Side vents just pull out, maybe tight but can leaver them as sponge dash usually goes back to normal
oh right will give that a go, once ive sorted these bits out then its to the exhaust and engine upgrade. I did want to put a BTCC spoiler on it but just cannot see how I could get the standard spoiler off and then fit the other one
