Altea-Paul
Hi I'm Paul from teeside about a month ago we bought a Altea xl 2.0 tdi it broke down on the first day luckily for us as the turbo was shot so a week later we had our Altea back with a new turbo :D anyway a few days later the flat tyre light came on I've checked tyre pressures and they are fine so I tried to reset it but it flashes once and no audible beep any suggestions ?
How long should it take to beep I've held the button for 2 mins ?
Should be about 3 seconds mate. Sounds like summat's fecked. :confused:
Try disconnecting the battery for 10 minutes or so, then reconnect. If no dice, then a scan with VCDS will possibly locate a fault.
Ok thanks for the help . Does the radio have a code ? Will I loose that if I disconnect the battery ?
I've got the same issue, what button do you hold in to reset? The mileage reset button on the speedo?
