No alarm from the factory?
May 10, 2023
29
Alarm doesn't seem to be working for my vehcile, weird thing is that the central locking works and there's blinking red light by the door when I lock the car so there should be able to test the alarm but it doesn't work.
Looked at the fuse box and apparently fuse 33 is for "self-powered alarm horn" which should be the alarm right? I tried inserting a 15 amp fuse and I realized that it doesn't even have the wiring for fuse 33 which leads me to believe that my car wasn't equipped with it from the factory.
Also I used VCDS to activate the unlock/lock horn sounds which "beeps" when you unlock or lock the car, it doesn't beep at all.
No alarm from the factory then?
SWANSWAY CUPRA Dealership
