No brakes when engine runing
JBY001
yer il bare that in mind, its bad enough knowing my car is stuck in a garage let alone if that was to happen
JBY001
if there was air in the brakes then wouldnt i still be able to pump the pedal when the engine is running and it go hard!:confused:
JBY001
you can pump the pedal as much as you want and it just hit the floor with the engine running.
JBY001
i asume so i dint see any leaks will check tommorow tho. just a bit more info inf it will help all brake hoses where clamped one by one untill all the brakes where cut off. the end result was that once again engine off pedal is hard in two -three pumps and engine on foot to the floor every time!
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Not sounding too good there mate
I'm confused by the pedal going to the floor only when engine is on but I'm not too clued up on the hydraulic schematics for the brake system.
Hopefully your garage will be able to sort all your problems
JBY001
appreciated thanks for your help tho. its weird how its been fine for 30 miles since iv changed the discs and pads and its only just happend since the fluid has been changed.:confused:
