No coolant temperature and false oil temperature
  • Thread starter Deleted member 133668
  • Start date
Hey!
Since yersteday my Leon 5f has an issue. The coolant temperature doesn’t appear… I used VCDS diag the coolant is -3 degree (when 22 degree outside…). I think the coolant temp. sensor doesn’t work anymore.
But, the oil temperature is incorrect. It shows 55-60 degree. Did the oil temperature break at the same time ? I have no default for the oil temp issue in VCDS.
Do you have an idea?
Thanks!
