Hi!
Since two months back I am an owner of a seat leon mk1 1.6 16v (engine code AZD). Barely know anything about cars but am learning, so far I have changed the cam belt and the master clutch cylinder. Since a few weeks I noticed the car hesitating and almost slightly jerking in certain gears mainly around 2500 rpm so figured it was time for a service. I then changed the oil, oil filter, fuel filter and air filter. While doing this I noticed:
- Some oil on top of the engine, which I believe is coming from the oil cap. The cap has a little opening one of the sides (to relieve pressure?) where it could be coming from.
- About 1/4 of the air filter was covered in sludgy oil.
- When unscrewing the oil cap when car is running there is a very slight amount of oil spitting out.
My first though was that it was merely the oil cap that was leaking, perhaps as i said from the opening on the side - why is it there? However I realised this probably did not cause the problem with the air filter.
So I have googled and tried finding out what the problem could be and read that it could be a faulty PCV-valve, dirty throttle body and some dreaded threads blaming it on piston rings (which apparently would mean the end of the engine?)
The car actually runs pretty well, so I am hoping that I have caught this early enough. I do not mind spending time fixing it, but am a total newbie when it comes to engines so am hoping to get some good advice from this forum. Any ideas?
