Hi eveyone. I have an ibiza 6L 1.4 BBZ engine. I recently installed a sandwich adapter with oil temperature and pressure sensors. Wired up the Gauges, all works fine. Noticed that the temperature gauge is reading quite high temps. When cruising on the highway i see temps between 95-115. When i step it a little more it stays on 115. Is the temperature normal for this engine?, because i think its too high (it should be around 95-100). Also the car has no oil cooler, not from the factory and not an aftermarket one, the filter just bolts on the block straight away. Thanks for anyone who answers
Στάλθηκε από το RNE-L21 μου χρησιμοποιώντας Tapatalk
