mattyholmz89
453
Huddersfield
So got up this morning thought I would do my weekly checks on car coolant tire pressure oil etc etc... oil was just above bottom marker on dipstick so filled up about 250ml and it's just over half way left it at that for now.
Now for the awesome part upon pulling the dipstick out the second time a little bit of the plastic yellow from the dipstick not the tube snapped off about half of the yellow dipstick bit now I managed to get the big piece out but im a little dubious as to whether a small piece has dropped down into the sump. Now I know that there are a few filters that will stop it getting through to the engine however will it cause any damage? The pick up pipe was replaced 3 months ago and had 0 blockage when changed (only changed because I had the part and mechanic had already dropped the sump to check...
Anyway my question is do I pay my mechanic to drop the sump for me and clear out the oil and pick up pipe to make sure or will it be alright having no prior blockage and the fact that it will only be a small bit down there if even that?
Thanks in advance
Happend to me mate small piece broke off and went down, I've just left it, it prob came out when I did my oil change
Thinking to just leave it until service time then tell my cousin to drop sump and clean it out check for any sign of wear them maybe change the type of oil depending... He said it was perfectly clear when he dropped it 3 months ago I'd say 250ml of oil in 3 month is negligible considering the rocker cover gasket needs changing so I can deal with the oil use it was more worrying over blocked pick up but I can't see a couple of tiny pieces blocking it too badly..
Should be fine mate I dropped a it down prob 3 month ago and I've had no problem, as for oil Im having to change again as I'm going through it like butter, used cheap asda stuff and never had to touch the oil, changed it to Castrol now topping up for 1st time in about 3 weeks not good.
**** hahaa I used millers nano drive 5w-40 and as I say it was just above bottom mark on dipstick put 250ml and it's above halfway now gonna change it for something else I think maybe used motul or something next see what it's like though the nano drive is good but cost £47.50 for 6l lol
