Okay to you experience chaps.....
Trickthedick
46
THis is probably a daft question but how does the CD/Radio come out?
Is this a whole console thingy or....just let me know
Only need to get to the plugs at the back of the std stereo......:whistle:
kriso
_______ C U P R A _______
Jan 29, 2007
2,325
Brighton
Stick DIN removal tools into the little slots at the bottom of the radio at each side and it will unclip and u can pull it out. Been covered loads of times.
Can use cable ties or thin bits of plastic if you have patience :)
RichieRich
Mk4 Golf GT TDi
Sep 17, 2005
2,367
Oxfordshire :)
www.bebo.com
get some vw radio release keys.. last time i went they gave me them for free... but i lost them so i ask my mate who has alot of different types and gets itout in 10 secs....you have to push them in then slide outwards...
Tom B
4,710
16
Northampton
I watched one of the techs at the local dealer do it with cable ties.
Put the cable tie at the left side of the left hole and the right side of the right hole and push in, it should pull the tabs in and release the stereo. You may have to pull out the panel underneath so you can get your hand at the back of it to lever it out. If it doesn't come out easily, it isn't released properly.
Ad Lav
vRS...
Nov 10, 2006
4,230
Kent
Get the stereo out, the single slot cage beneath will slide out then you have a double-din slot to fiddle around in, plenty of room.
Trickthedick
46
I was thinking of the placement of the button bit...would seem to go best at top of console between the two vents
