overheating!!
Trimmer
68
London
:cry:
stuck in traffic when i noticed the temp gauge shotting upward. pulled over and opened the bonnet. The water tank was bubbling like a kettle.. so i released the pressure and waited for the car to cool down. The aircon has also stopped working... checked all the fuses and all seems to be ok. any ideas??
TimD
472
Have you checked the fuses above the battery?
I think i read that they can suffer from corrosion, so check them all.
Trimmer
68
London
yeah ive checked them.. they seem to be fine.. would you suggest changing them? Are they regular fuses i can purchase from halfords?
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
could be that something tripped out so ur fans werent cooling ur engine
theres a small black cover over the battery, open this up and theres a series of connections, sometimes these get corroded and i believe one is for the fans. might be worth looking at
TimD
472
What was the solution for future reference?
Helps with searches then :)
Trimmer
68
London
hmmm well it seems to be a lose connection somewhere around the battery... went out hour an hour later and it wasn't working again.. then i move the batt the heard a click followed by my rad fans started... ive changed the three 30amp fuses now going to give it an hour.. see what happens
TimD
472
Go round with a socket tightening all the nuts and bolts around the battery. Mine once came loose and it did all sorts of weird things.
Speakers popping, lights dimming, etc, etc.
cruising03uk
street sleeper
May 10, 2006
133
north london
same problem here boys i have ibiza mk3 cupra only in traffic it goes up quick sometimes putting interior fans on r enough
i noticed 1 of the fuses was 25 amp an melted like a bitch one on far right but after replacing this it hasnt helped i replaced wit a 30amp fuse as dealer recommended over phone but fans still not working and car only overheats in traffic after 10mins or so but perfect as soon as i start moving and fine when gettion thrashed about everywhere when the roads are clear. any more news much appreciated as vag com machine says mnothin and has no fault codes???
cheers
dave
acidstrato
Dec 9, 2004
5,942
u shouldnt be driving your car if the cooling fans are faulty
most cars will over heat in summer traffic, if the fans come on though and the temps go down...thats normal, maybe a top up of coolant could help
but if the fans arent coming on at all then u shouldnt be out driving really
Apr 28, 2003
2,624
cheers
dave
Actual fuse holder has melted internally causing the current to ark across to the fuse causing high a lot of heat.
