Nov 3, 2026
I've ordered a new Cupra Born V2 79kWh, Aurora Blue, delivery March 2027. Can't wait!
I visit Spain 3 times a year, each for 28/30 days. My current car, Toyota Corolla saloon has a flat battery in that time. There is no access to mains electricity, parked outside private parking. I've been using a solar trickle panel successfully - except Winter!
Cupra UK technicians will not allow this OBD2 solar panel on the Born. May affect sensitive electronics!!
I also have a Noco boost starter as a backup.
I know older Borns used to have trouble with parasitic drain, but things have gone quiet for newer models with updates. I'm hoping things are now better??
Any evidence one way or another please?
The newer battery management system *should* trickle charge the 12v battery off the HV battery at a standstill providing the charge level of the HV battery is sufficient enough.
Thanks James. That's what I thought.
Re: CUPRA Born
However I wrote to Cupra UK asking some searching questions. I know that Cupra won't give a definitive answer, due to worry about litigation! What do you/ anyone think of the reply. It doesn't look good for people in my situation. I can't take a risk of parking in an airport car park.
"Thank you for your patience while we consulted our Technical Team regarding your concerns about the 12V battery and leaving your CUPRA Born unused for an extended period.
Please find below the information provided by our Technical Team:
Privacy Mode / Offline Mode
Privacy Mode/Offline Mode does not reduce the vehicle's electrical consumption while parked. Therefore, enabling this mode is not necessary to preserve battery charge during periods of inactivity.
Remote Connectivity and Automatic Software Updates
Disabling remote connectivity or automatic software updates does not reduce 12V battery drain.
Over-the-air software updates are only carried out with the driver's authorization. Before an update begins, the vehicle will advise how long it is expected to take. Updates typically take approximately 45 minutes.
Further information can be found here:
https://www.cupra.com/en/owners/ota-updates
12V Battery Monitoring
While the vehicle is locked and switched off, certain systems can continue to monitor its status, such as whether doors, windows, or lights have been left on.
However, some vehicle systems may only perform checks or generate alerts once the vehicle has been switched on again.
DC-DC Converter and 12V Battery Charging
The 12V battery is normally replenished while the vehicle is running or while the high-voltage battery is being actively charged.
The system is not designed to automatically recharge the 12V battery solely because its voltage has dropped while the vehicle is parked and unplugged.
Extended Periods of Inactivity (30–40 Days)
CUPRA's recommendations for longer periods of vehicle storage are outlined in the owner's manual, including maintaining the high-voltage battery at the advised state of charge.
Our Technical Team has confirmed that there is no additional manufacturer guidance beyond the information provided in the owner's manual.
Battery performance during extended periods of inactivity can vary depending on several factors, including the vehicle's condition, battery health, ambient temperature and usage history. Therefore, it is not possible to provide any further specific recommendations or guarantees regarding battery discharge during this period.
We hope the above information clarifies the situation and addresses your concerns"
